| Message |
There are several connectors/solenoids on the ds near the fuse block that could cause you to throw this code. Check all the connectors in that area. Make sure you have no vacuum leaks in any of the 142+ vacuum lines in that area. A third offender could be your gas cap, try to open the cap and see if it's holding pressure. In the same area, there's a solenoid accessible near the ds rear wheel well that can throw that code, check vacuum lines and connectors there as well.
Cheers, JBrobst "A life spent making mistakes is not only more honorable, but more useful than a life spent doing nothing." George Bernard Shaw |
